iPad is bent and screen cracked. I’m scared to bend it back
I want to replace the screen but with it being slightly bent, the new screen wouldn’t go on correctly.
Esta é uma boa pergunta?
I have repaired many iPads in similar condition before and the metal is actually really easy to bend back in place. I would definitely remove the motherboard and battery very carefully before attempting to bend it back though and should be left to a professional if you haven't disassembled an iPad before. Backup your data before just in case. Once the motherboard and battery are removed then the aluminum shell is easy to bend back into its original shape.
Esta resposta foi útil?
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 82
Duração total: 331
