Ir para o conteúdo principal
Samsung's third iteration of the Galaxy Watch with a newly integrated BioActive Sensor. It was released August 27th, 2021. Model SM-R860, 40 mm, non-LTE version.
19 Perguntas Visualizar todos
HR sensor not working after 12m diving
After a session of diving(12m pool water) the HR sensor stopped working.
I opened the watch 4 and no water damage or indicator marked.
Where is the HR sensor located and what can I do? (I suppose in the backplate but the green light works, so maybe a part of the sensor?).
Also seems not to be parts for this available.
Factory reset done with no difference.
Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You can try cherching parts on Ali Express , it can be a board issue that need professional micro soldering
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dushu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 46
