Ir para o conteúdo principal
O controlador V2 possui diferentes gerações. Você está vendo a Geração 4.
R2 button not working
So recently I replaced both joysticks on my controller and since I did this the R2 button does not work. I cleaned the contacts, tried to replace the mylar but still nothing. The L2 button is triggered when I touch the joystick contacts with my finger. Can anyone help?
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
I think we'll need to see pictures of the inside to answer this the most effectively. Feel free to add some to your original post.
This could just be some parts aren't quite aligned properly, or it could be there is some damage to the giant flexible cable that carries all the button signals.
Since replacing the joysticks requires soldering, we'll also want to see pictures of your work to be sure nothing on the board is amiss.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I just posted a photo if you can take a look
por Compartilhar
Adicionar a sua resposta
Denis Fluturas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 1,104
