Ir para o conteúdo principal
Este é o guia de reparo e manual de serviço do Asus VivoBook 15 F571. O Asus VivoBook 15 F571 é um laptop para trabalho diário e computação, mas também pode ser usado para jogos e edição de vídeo.
Issue with my Battery
My laptop shut down suddenly while I was using it plugged in and it didn't turn on. The repair guy at the Asus service center said it was a mother board problem. After 1 week he called me and said your laptop is ready, but it's only working while it's plugged in, he said it is a battery issue and changing the battery will fix it.
I ordered a new battery from ifixit and installed it in my laptop, but it isn't charging it stuck at 1%.
Any one know what's the exact issue make sure to reply.
Any fast replies will be appreciated.
Thank you.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Check with the adaptor if the adaptor is not supplying required charge it may be unable to charge
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Vivek Vardhan Naramreddy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 651
