Ir para o conteúdo principal
An external optical drive by Apple, essentially a rebranding of the MacBook Air SuperDrive.
35 Perguntas Visualizar todos
Pergunta encerrada
superdrive cable is near to dead
As for other products this cable is badly build. My macbook air superdrive cable is near to dead.I fixed wires with tape but they'll not hold more time.
Could a find a spare one, and it's there a solution to make it universal. Use it in all my macs.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Esta resposta foi dada inicialmente para uma outra pergunta.
Repairing
the cable is possible but you might have to cut it shorter and solder it inside the case. Depends upon where the fault is. You can find used Superdrives at reasonable prices for parts, just ensure the one you buy has an intact cable.
If this answer was helpful please remember to return an mark it Accepted.
Esta resposta foi útil?
Pontuação 0
I have a similar issues with my Apple USB SuperDrive too. At the beginning of the drive device,the USB cable is little wore out.
Do IFixit have any solution or guide that you can show the Apple end user on how to replace the USB Cable that is attached to the Apple USB SuperDrive?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,292
