Ir para o conteúdo principal
Eighth generation of iPad, released September 18, 2020, available in 32 or 128 GB models. Model Number A2270.
13 Perguntas Visualizar todos
Can I put an iPad 7 lcd in An iPad 8?
My lcd is broken and I found an id locked iPad 7 for cheap, can I put the lcd from the iPad 7 into my iPad 8, and is the lcd going to be affected by the id lock on the iPad
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
7th 8th 9th gen iPad use the same LCD, id lock from donor iPad won't affect the display functionality on new iPad.
Esta resposta foi útil?
Pontuação 1
Yes you can use the same LCD from the 7th, 8th and 9th Generations. The ID lock is something that is built into the software not the hardware. You shouldn't have any issues with the LCD.
Pontuação 0
Adicionar a sua resposta
Taylor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 43
