Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
No Power Not booting
Plug in magsafe charger indicator always green, fan not spinning, measured voltage across fuse on board with magsafe charger plugged in (it reads 19volts ), I'm pretty decent with fixing iPhone logic boards, this is my first with MacBook logic board.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I’m impressed the logic board is so clean!
I do see an area that needs investigation around the DC - In Board connector.
At this point you need to grab the schematics and board view drawings to trace out the power rails. I’m suspecting your issue is within the MOSFET power switching logic. Using a DVM you should be able to see what’s happening. Often times the knock-off charger has damaged them.
Esta resposta foi útil?
Pontuação 0
3 comentários:
@danj thank you for the reply, I'll appreciate if you can point me in the right direction where I can get a good schematics for MacBook logic board
por
@n3dtech - Locate the logic board number it should be either 820-2530 or 820-2936 the images you posted are too blurry for me to ID.
Then search the internet for number and Schematic
por
Okay thanks.
por
Adicionar a sua resposta
n3d Tech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 142
