Ir para o conteúdo principal
Guias de reparo, desmontagem e informações sobre a resolução de problemas do Apple iPad de 9ª geração com Wi-Fi, disponível com 64 ou 256 GB de armazenamento. Lançado em setembro de 2021. Identificado pelo número de modelo A2602.
My fault - poor skill - Did I damage my lcd?
Hi all,
My iPad front glass was damaged but the screen was OK. I brought a front screen replacement and tried to do it myself.
The progress did not go well because all the small pieces of broken glasses. And after I finish the replacement and reconnect again. My lcd turn to black and white strips.
Imagem
Imagem
Imagem
Imagem
May I know what should I do to save the iPad.
Thanks a lot. Sorry to take your time.
Added photos for the LCD connectors as below:
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
5 comentários
Could you post pictures of the LCD connector? Both the board and flex cable themselves?
por
@hootonberg Thank Jesse,
I add some pictures of the connectors. Grateful for your help.
por
@samchoo sorry I should've been a bit more specific. Could you disconnect the connectors and send pictures? I'm trying to see if there's any bent or damaged pins.
por
@samchoo Did you disconnect the battery before performing the screen replacement?
por
Hi Andrew, thanks. No, I think I didn't. I just follow one YouTube video.
por
Adicionar um comentário
1 resposta
Solução escolhida
This doesn't look like display damage to me. This looks like missing data lines to the display. And/or backlight issues. That could be a torn or punctured flex cable. Or it could be an issue with some of the board components around the display connector. I don't see any damage to the cable in your pictures, but that doesn't always mean there isn't any. There's a lot to that cable that isn't in the photos. (The one to the LCD)
Disconnect everything again and peel up the sticker around the connector. See if anything looks crooked, or damaged. Post pics of that if you're unsure. Here's a normal one for reference.
Imagem
This could also be an issue with blown backlight components if the display was disconnected with the battery still connected. You are less likely to see anything if this were the case. But still worth looking at.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks a lot. I will try again!
por
Adicionar a sua resposta
Sam Choo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 595
