Ir para o conteúdo principal
Pergunta encerrada
Why did my screen shrink to one side?
The right side of my screen is black. The actual screen has shrunk to the left side. How do I get it back to full screen?
Update
Hp Pavilion dv4 Notebook PC
3.00 GB
64 bit operating system
Windows 7 Home
Esta é uma boa pergunta?
Pontuação 0
3 comentários
iam having the same problem. i am using hp centrino 530.screen was ok few days ago.now missing 4'' from right and its black. one inch from bottom but its not black its stretched blue. screen is shrinked and i can see all icons. nothingis missing or out of the screen
por
lost my screen vertical borders by two inches per ide????
por
I clicked my screen laptop his going inside and bubble coming what is this
por
Adicionar um comentário
10 respostas
Pergunta mais útil
I fixed my screen's positions by doing this.
- Go to Control Panel
- Select Intel GMA Driver (I think this is the Graphics card, so just select yours if it is different.
- Go to Display Settings
- Select Advanced Settings
- Change the position by selecting the arrows.
- Apply and select Ok
Esta resposta foi útil?
Pontuação 23
16 comentários:
This was exactly what I needed, and it worked! Thank you for posting it!!!
por
love the concise tip :)
por
Many thanks Balinda problem solved
Happy New Year
por
Using WIN 10 on a Dell. Screen shifted to left after kids played Mine Craft. Tried above, but no advance settings. Under basic tried "Center" and other options, but nothing changed. Can anyone help?
por
Hey There make sure to mark this response using the accept answer button! thanks!
por
Exibir mais 11 comentários
Esta resposta foi dada inicialmente para uma outra pergunta.
Go to Control panel and find the device manager
see if you can see the Display driver and try updating the video driver .
checkout the resolution and in display settings change the size for more steps - click http://fixingblog.com/fix-screen-display... , thanks and welcome
Pontuação 10
1 comentário:
Why can't this be simplified so even vision impaired people can use a computer?
por
I had the same issue, solved it using:
Right click on desktop > Graphics options > Panel fit > Center Image
Pontuação 8
2 comentários:
Right click on desktop > Graphics options >Rotation>Rotate to 0 degree
por
Thank you!! This worked beautifully
por
Go to the monitor and select auto then choose size and position. Reset
Pontuação 3
1 comentário:
Thank you so much.......It really helped me.
por
Okay so i had the same problem and i have Windows 10 so heres what i did, dont worry its very easy to fix it. All you need to do is go to settings choose display settings then choose "display adapter properties" see if you are windows 10 user you just need to scroll down and youll find this option under "Related settings". Once you click on that further a window will open, you my friend just click on graphics card control panel and see the rotation option. Your rotation would be either 270 or 90/180. So you just need to choose 0 degree as your Rotation. And just click on Apply changes on the lower right hand side of the window and bingo! Problem solved
Pontuação 1
Go to the system before starting the windows, F9 (Load default) and F10 (save and exit). your screen will go to the center after starting the windows.
Pontuação 1
If this is a laptop, re-insall the video driver.
If this is an external monitor, make sure you have the proper inf for the monitor and the most current driver for the video card.
Check the resolution that the video card is set to and the native resoulution specifications of your monitor. They should be the same.
Please post the exact specifications of your system.
Pontuação 0
If running Windows, can you still see the clock at the far right-hand corner of the screen ?
Modern laptop screens cannot be resized to lose one side of a display, the picture will automatically appear centralised and the screen will always force a full screen picture if possible, but cause text to appear twisted/stretched in some way.
If your clock and other desktop items have vanished off the right of the screen inside the black area, then it's your screen at fault and will usually need replacing, or the flat cable at the rear of the actual screen may need refitting/replacing, a simple job for a technician.
Some laptops have an ability to use software in the graphics card software to adjust the picture and move the display around, cut bits out, rotate it around etc. It may be worth checking there too.
Pontuação 0
3 comentários:
Yeah everything looks really good, clock is still there, nothing is stretched. Just a quarter of the screen looks like it's missing on the right side and an inch at the bottom.
por
I could not fix at all
por
No; you got . Thank you.
por
Make sure you boot into BIOS (hit the key that is listed as Setup, probably F12, right after turning it on) and check what the computer is detecting as your screen. Often, it ends up refreshing detected hardware, and behaves normal.
If anything, it must be Windows setting the resolution wrong. You can go into Control Panel and select Appearance for whichever version of Windows you have. From there, you can just select the largest possible resolution and see what happens when it adjusts.
Pontuação 0
i click the button on front of monitor and clicked auto management in image management
Pontuação 0
1 comentário:
Where is the option for auto management?
por
1 Click the menu button on your screen
2 Go to "System Setup"
3 Select " All Reset"
4 Confirm
I've been wrestling with this problem all day and after hours of googling and randomly trying stuff this finally worked for me. No thanks to the many forums with unnecessarily lengthy posts on this. Hope this helps you as well.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 36,562
