Its it possible to replace MacBook Air 2012 keyboard with MacBook Pro
Hello,
Its it possible to replace Macbook Air 2012 keyboard with Macbook Pro mid 2012 it it compatible?
UK layout
Thank you
Esta é uma boa pergunta?
Hello,
UK layout
Thank you
You do have to remove quite a bit of parts the logic board, dvd drive, and speaker. It can be challenging but I found a video doing a keyboard replacement and it looks like it is challenging. Also if you have done laptop repairs before it might be easier. Also it helps with having a dedicated work space so you can organize all of the screws. Here is the repair video I would recommend. https://youtu.be/EEs6Nl34xuc I have not done a keyboard replacement on MacBooks so that is the most I can do to help.
Esta resposta foi útil?
Hi there,
Although your desire to help is very much appreciated and welcomed, I do have to point out that you really didn't address the question that was asked, which was whether or not the MacBook Pro keyboard will work for a standard 2012 MacBook, specifically the one with the UK layout.
Unfortunately I have no idea either, but hopefully someone who does know will jump in and help out.
Hello @buildingbros Thank you for your reply and yes i agree with @dadibrokeit hopefully someone here who have more experience who have done this job will be able to answer if it is a YES or NO
I'm still searching all over the web with no luck so far.
Thank you guys :)
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 29
