fast charging doesn't work properly
Suddenly, when I plug in the charger on my phone, it keeps connecting and disconnecting all the time. But when I use another USB cable that doesn't support fast charging, it works fine but charges slowly. The problem occurs just with fast-charging cables; the adapter works perfectly on other devices, so I'm sure the problem is in the phone.
Esta é uma boa pergunta?
Ass you said it is connecting and disconnecting so the problem is your Cable
Maybe you will need to buy a cable that is fast charge se how many watts is your charger and get a cable that supports that wattage (a fast charge cable)and try to clean your port if its dirty. That might help too
por Ellusion Compartilhar
Thanks. I cleaned the charging port after I posted the question and now it owrks properly as it should. But thanks anyway.
por Roudi Alzkemi Compartilhar
Good My friend!!
