The device is too cold to charge
Charging is stopped when the charger is inserted because the temperature is too low. is displayed and charging is not possible. I replaced the NFC coil, main board and sub board, and charging port, but it didn't improve. Also, when the sub-display is attached, it freezes at the startup logo and cannot be started, but when it is removed, it can be started normally. Which component do you suspect is defective?
Esta é uma boa pergunta?
Pontuação
0
