Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
30 Perguntas Visualizar todos
Restore to factory settings without my forgotten password
How do I force my ipad mini into factory settings when I can't remember password
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hello! If you try to power the iPad on while holding the home button it should boot into recovery mode, then using a computer you can restore it to factory settings. If you have find my ipad enabled you may run into issues if you dont' have access to the icloud account its logged into anymore, as apple devices are tied to this ID when that is enabled, and you wont be able to use it again without that. @aklyman58
Esta resposta foi útil?
Pontuação 0
Plug the device into the computer, then press and hold the power button and the home button together at the same time. Once the tablet resets, let go of the power button while continuing to hold down the home button.
Pontuação 0
Adicionar a sua resposta
Aklyman58 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 21
