Ir para o conteúdo principal
The left side of the headphone stopped working
When the left side of the headphone stopped working I tapped on it again and again , it has started again but it seems to be playing at a lower volume than the right side . I think it's a loose connection of some sort and needed help in opening it up and checking on the problem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
I've had this problem too.. The issue I had seemed to be related to the two contacts of the speaker in the left ear shell. There are two springs that press on two contacts on the pcb. They seem just barely long enough so even the slightest play in the plastic would cut the sound off. I soldered two small blobs on the contacts so they would make better contact with the springs and that solved the issue for me. To open up the shell there are 4 clips under the cushion at a 45 degree angle to the stem. Press two of these in with a small screwdriver from the outside to open it up. After that remove the 3 screws and then you can remove the speaker part and see the contacts.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Aum Padia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 171
Ao todo: 2,585
