saw starts runs wot will not idle down and run
will start and run at high speed will not idle replaced carb same results help
Esta é uma boa pergunta?
Pontuação
2
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 52
Ao todo: 465
Throttle linkage incorrectly setup?
por F Dryer
No It is set up proper. turned out to be a pinhole in the carburetor fuel pump
por Rudy
do you mean the metering diaphragm, i have the same issue where it will start and run at wot but as soon as i let off it dies within 10 seconds
por Peter
