This is a measure of battery capacity relative to when it was new low
This is a measure of battery capacity relative to when it was new low capacity may result in fewer hours of usage between charges
Esta é uma boa pergunta?
@seyomehail76123 Sounds like it's just telling you that the battery has reduced capacity. This is normal as a battery wears and accumulates cycles over time.
If you are alright with shorter battery life, it is fine to ignore the warning. When the battery life gets so short that it is impacting your use of the phone, you can look into changing the battery.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 65
