Why is my keyboard typing wrong words
Whenever i press 7 it prints y7, whenever i press y it prints 7, whenever i press caps locks it prints 2 ,@ not typing.
Esta é uma boa pergunta?
@daniyalnaz89220 Did you spill anything on the keyboard? You can try an external keyboard, if the same problem doesnt come up with that, then the problem will be solved with a keyboard replacement.
Esta resposta foi útil?
Well Go to Control Panel and select the group Clock, Language, Region. Select language and choose Advanced Settings. Locate the option Override on Default Input Method and select preferred language from the drop-down menu. Set the Override for Windows Display Language to the same language, hit OK, and restart your computer.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 49
