Why is my screen showing distorted images/ colors?
Veja o conteúdo da imagem:
Esta é uma boa pergunta?
There are a few reasons why your screen might be showing distorted images or colors. Here are some of the most common reasons:
Here are some things you can try to fix this:
If you have tried all of these things and you are still having problems, you may need to contact a computer repair technician for help.
Esta resposta foi útil?
This is a SNES not a computer. So not sure that if what you put applies to some degree or not here.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 147
I have tried different power supplies, RF cable and R/W/Y composite cables. No difference. Also cleaned cartridges and pins in the console.
por Talonrevenge
@talonrevenge Have the electrolytic capacitors on this console been replaced?
por Andrew S
@andrewsawesome not that I am aware of.
por Talonrevenge
@talonrevenge Have you cleaned the pins on the video connections or the cartridge connections?
por Justin Castle
@erelectronics yes I have cleaned them.
por Talonrevenge
Exibir mais 2 comentários
