Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
How do I fix my LCD screen?
Originally, just while using my MacBook as usual, the screen just all of a sudden went completely black (with a thin white line at the bottom). The Apple store said that we would have to replace the LCD/LED screen.
Thus, I had a family member replace the screen. So now, the screen lights up, but it is completely white and does not display the actual screen.
The computer itself still works completely fine and everything is visible and workable when plugged into another monitor.
Any idea on how to fix this?
Image of current screen situation:
The whole screen
It also has this odd little red arrow?
Thanks for any help!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Please tell us more about the screen exchange. Did Apple actually run any test(s) on the laptop? Did you buy new or used? Just the LCD or whole upper clam shell? Same LVDS/video cable or different one? Do you still have the old screen and cable? Do you have the original install disk(s) that came with the machine and/or the original hard drive? What are the last 3 characters of your serial number?
por
Did Apple actually run any test(s) on the laptop? Probably yes; they told me the laptop needs a new LCD screen, otherwise it’s working fine.
Did you buy new or used? Brand new one.
Just the LCD or whole upper clam shell? Just the LED backlight LCD.
Same LVDS/video cable or different one? Looks identical to me.
Do you still have the old screen and cable? Yes, I save the old screen.
Do you have the original install disk(s) that came with the machine and/or the original hard drive? I didn't get any discs when I got my laptop.
What are the last 3 characters of your serial number? F5W
por
Adicionar um comentário
1 resposta
Solução escolhida
The odd little red arrow is most likely not a problem with the LCD or the laptop. The chances are that is a mark put on a protective layer of film, from the factory, to remind the installer that the film is there and needs removed. The factory puts the film on there to ensure that the polarized film on the LCD is not damaged prior to installation. It is easiest to catch the film at the corners. The bezel will have to be removed to remove it.
I wouldn't remove that film just yet. I would double check the LVDS/video cable connection on the motherboard/logic board to make sure it is seated properly - that may be the problem. If that doesn't solve the issue, I need the manufacturer's part number to both LCDs, including the revision number, to verify compatibility. Those numbers will be on a sticker on the back of the LCD. I would call the vendor where you purchased the new one to get that number or it might be on your receipt. Sometimes with revisions of a LCD model number compatibility changes. You have a new LCD and a new LVDS cable I question the compatibility of the LCDs. If they are compatible then I would say the LVDS cable or connector was damaged during installation. In which case you could replace the new cable with the old and inspect the connection on the logic board.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Tiffany será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,924
