Ir para o conteúdo principal
Repair, disassembly, and troubleshooting information for the Steam Deck with LCD display, a handheld gaming console made by Valve, released on February 25, 2022. Identified by model number 1010.
Where can I find parts not on iFixit?
I was doing a full case swap and accidentally broke part MEOJ24900KDL. It's the long ribbon cable that goes along the top vent. I've tried looking in few places but can't seem to track anywhere down to get a replacement. I also suspect I broke the ribbon cable from the display to the motherboard, but I might just buy the upgrade screen anyways, will see. Anyways, whatever help would be much appreciated!
Esta é uma boa pergunta?
Pontuação 4
16 comentários
please check that part number
por
@mayer I did check it again and got the same number of the barcode. However I was using Google lens which might be the problem. Im going to try a different barcode reader but for now I just uploaded the pictures if the part and barcode.
Edit:
I tried 2 more qr readers and got the same part number off of both.
por
@drevis25 what else does it say on the ribbon cable? To the left of the FPC....
por
@oldturkey03 Three things, 2248 TSF (in small print) F7A_MIC_FPC, in that order.
por
@drevis25 looks like the Mic Flex. Now just to find it......
por
Exibir mais 11 comentários
Adicionar um comentário
3 respostas
Solução escolhida
Hey guys I wanted to let you know I bought my replacement from for this eBay seller:
https://www.ebay.com/itm/115989144859?mk...
Mine hasn't arrived yet but I"LL keep you updated once is been installed
(REED DESCRIPTION TO WHICH DEVICES ARE COMPATIBLE WITH !)
Esta resposta foi útil?
Pontuação 1
3 comentários:
Looks legit!!! You are my hero!!! I'll wait for an update before by but again it looks promising.
por
As soon I get it installed and tested I'll let you know 😉👍
por
Update: Mic Flex (F7A) arrived in great shape and good packaging.
I have made the installation and it worked flawless, I also upgraded the LCD to a 1200P from DeckHD and changed the shell for a clear version from Jsaux.
por
@drevis25 given its a new device, I'd contact Steam and see if they'll let you purchase new parts directly. It may be a while before used parts start showing up on eBay, that usually only happens once warranties start running out.
Pontuação 0
kasynparts have this parts
Pontuação 0
Adicionar a sua resposta
Drevis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 81
Ao todo: 1,878
