Ir para o conteúdo principal
Um tablet desenvolvido pela HP em 2011 que roda a plataforma webOS. Possui uma tela de 9,7" e está disponível em 16 ou 32 GB. O reparo é simples, mas requer tempo e persistência.
56 Perguntas Visualizar todos
Touchpad will not power on.
We bought a Touchpad at one of the firesales online; thus no warranty. Had it 3 weeks and it appeared to be stuck on the last page viewed (on a slant). We could not exit or power off, until we simultaneously pressed the volume up and power button at the same time. Now it will not power on. Have tried numerous cords and nothing. Help
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
8 respostas
Pergunta mais útil
try this reset mode- hold down power button and press the home key button on the front of the touchpad 15 times in a row. then release power.
Esta resposta foi útil?
Pontuação 6
1 comentário:
Thanks, you saved me. My Touch Pad was stuck in retart...
por
Battery is the most likely reason. It sometimes (software bug?) lets the battery discharge below the safety levels for LiPo cells. This is your case since you let it "stuck" on a page until the voltage fell below safety levels. If the circuits detect that low level voltage, it does not even charge because it is said to be dangerous to charge a deep-discharged LiPo (fire danger).
Your best shot is to buy a replacement battery and have it replaced or do it yourself.
So, try to replace the battery. I did so and it worked...
BTW, I also tried reviving the battery by slow charging it with a RC LiPo charger but it was too deeply discharged!
Pontuação 4
2 comentários:
how long do we wait
por
From where i got the new battery ???
por
When TouchPad will not respond to the power button and you know for a fact that the battery has a charge and or is plugged in to charger. Hold the power button along with the Home button and hold them together for 10-15 seconds. TouchPad will go in to a hard reset and will boot with the HP logo. You can then reboot to boot on to android if needed.
Hope this helps.. jcs
Pontuação 1
I think your best shot is to change the battery... It's not VERY hard to do but you have to be carefull in order not ot kill the device. Maybe you can have an expert do it for you.
Pontuação 0
Cuado estaba desconectando el microfono, estaba levantado el clip blanco que sugeta la lamina, se deprendi y la perdi. Como puedo solucionar el problema para reconectar el micrófono.
Pontuação 0
ok try pressing the big hp logo the volume down and the power button for 30s
Pontuação 0
Thank you to Kathy, Vector Vector…and everyone for the postings…. Very helpful, finally my old HP Touchpad alive again. Thank you to all of you again!
Pontuação 0
How do I do while manufacture reset I’ll touch base
Pontuação 0
1 comentário:
How do I do a manufactured reset all of the model number 014328003945259
por
Adicionar a sua resposta
Kathy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 40,328
