Ir para o conteúdo principal
The Ryobi Electric Lawn Mower, released in 2020, is a cordless push lawn mower with a 20” cutting deck. It runs on a 40-Volt, 6AH lithium-ion battery and provides power equivalent to gas-operated lawn mowers with its brushless motor. It is recharged with the included 40-Volt charger. Model names include RY401011, RY401011VNM and RY401011BTLVNM.
3 Perguntas Visualizar todos
Is there a way to fix a broken rear tire, part number - 330072007?
The inner part of one of my Ryobi lawn mower's rear tires is cracked. Replacement isn't possible until 09/14/23. Is there a way to fix the tire?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This vendor (example only, if Ryobi does not have) appears to have the replacement wheel in stock: https://www.partswarehouse.com/Homelite-...
Could you share a picture of the cracked wheel? Adicionar imagens a uma pergunta já existente That may help with repair ideas; a plastic wheel may be difficult to repair adequately for this application).
I looked to see if anyone has made a 3D print available of this wheel and didn't find one (my idea being that you could get a service to print you a new plastic wheel--like this fix BCG800XL Grinder Jamming due to Worn Impeller -- that might last at least a while (but probably not be cost effective or durable enough in this application as a long term fix).
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Breville BCG800XL BCG800XL Impeller
Guia
Moderada
10 - 35 minutes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Albert Einstein será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 122
