I have a problem with the TouchPad
Hi, I’m Vivek Chaudhary from Rewari
I have a 15” MacBook Air with problems with TouchPad
Esta é uma boa pergunta?
This system should still be covered under Apple warranty as it was just released. Are you sure you picked the correct system? To be sure plug in your systems S/N here EveryMac - Lookup see what it tells you, the newer models won’t report correctly, even still let us know.
As to your problem, did you have a liquid spill (or get it wet) or damage the system in someway?
Esta resposta foi útil?
you should get the trackpad replaced i believe,thats what it is most likely like 99% chance that its that
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 110
