Ir para o conteúdo principal
Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
Is it possible to move keytops from A1314 to new keyboard?
Hello,
I have an A1314 keyboard with Russian letters. Is it possible to move keytops from this keyboard (only letters) to any other more modern Apple Magic keyboard? Are the clips compatible?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sorry that would be a bit tricky! These key caps are easily damaged trying to shift them and they aren’t available as a replacement.
The better way is either using stickers to alter the keys labels, or, use a silicon cover. Besides some keys won’t switch over cleanly.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Are the caps harder to remove on this particular model? I saw the instruction for other Apple keyboards and it looks pretty straightforward. Do you know if the caps are compatible with other models?
Are the caps from modern MacBooks compatible with any model of Apple keyboard? I know the store on Aliexpress which sells Russian caps for Macbooks
por
@romanchernyak - Bluetooth or USB Keyboards are not the same as the MacBook or MacBook Pro systems keyboards! So don’t confuse the two. While they appear to be the same from the outside the construction over the years have changed across all of the different series.
To be clear I didn’t say they couldn’t be taken off, just that you will have a high degree of damaging them as well as when you attempt to move them about. And some keys are slightly different depending on its placement.
Aptly, the KeyCaps for this keyboard where never offered as a replaceable part, while some parks houses take old dead keyboards appear to sell off the parts I’ve never found them when I was looking for my own keyboard.
Given the cost it would be cheaper and easier and in the end a better useful keyboard to just to get another keyboard.
por
Adicionar a sua resposta
Roman Chernyak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 153
