Newly installed MBP Battery dies at 7%.
I just installed a new battery into my Macbook Pro. It was an aftermarket battery bought from Amazon.com.
I installed the battery and turned it on. It display 99%, ran fine for a short while and then died. I realized I needed to restart the SMC, so I did that (started holding Ctr+Opt+Shift on left side until power light went green then amber, then restarted it and held Opt+Cmd+P+N until it restarted.)
Afterwards, I followed instructions to fully charge the device to 100%. It stopped charging at multiple points (it seemed to be whenever I closed the laptop? I would have to reset the SMC to get it to start charging again.)
Once I reached 100%, I left it overnight, then started discharging the battery. Used it as normal, like the guide suggested (But forgot to turn off all power management options), and it died at about 7%
I then left it sitting for 5 hours as suggested to try to let the battery 'fully drain.'
After 5 hours, I plugged it in and started it again, the battery reads 7%.
I'm not sure what I'm doing wrong, or how to get it to understand that this is actually 0%.
Esta é uma boa pergunta?
