Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
547 Perguntas Visualizar todos
Why is my MacBook Pro shutting down after hitting a key
My MacBook will shut off after I release a key. If I keep holding the key the MacBook will stay on until I release it. This includes the power button but not any the the modifier keys (ctrl, shift, option, etc.)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Are you running it with the charger? And are you sure it’s charging.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes it’s taking a charge and yes I have tried it with and without it plugged in
por
@christophe70009 - I’m not sure if the system is taking the power. There have been issues within the power circuit in this series.
You’ll need to get a USB-C power meter to plug in-line with your charger to test things. Make sure you are using the Apple cable as not allUsb-C cables are fully wired or don’t offer the heavier gage wires for the power lines.
And lastly, given the system age you are likely hitting the batteries end which could be the root issue here.
por
Adicionar a sua resposta
Christopher Gassen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 22
