Can't reset gfci
The built in gfci in the cord will not reset. How can I fix it?
Esta é uma boa pergunta?
@rickystuart I would check to see if there is actually something wrong with the cord which prevents a reset. If the cord is okay (for sure?) then you may have to replace the GFCI. The GFCI may have become faulty or it lacks a connection. If I remember right those use security screws which "prevent access". Replacements are available on select sites.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 398
