Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Strange screen incompatibility issue
Hi, I’ve run into a weird problem with a screen replacement for an iPhone 8 Plus, the factory value is C3f for the screen, I bought a C3f screen refurbished replacement, but when installed it has no touch, the screen works on other 8 plus phones, I check the serial on the old screen, and it starts with C190.. I have no idea what that is, I can’t find any info on it, but it’s the only one that works with touch, even though it doesn’t match the factory value in 3utools and JCID
Esta é uma boa pergunta?
Pontuação 0
2 comentários
where did you buy the screen from? Was it like an OEM refurbished screen?
por
Yes, the new screen works on other iPhones without issue, but this one 8 plus, refuses to work with any screen but the one that broke, and that screen isn’t the original, the phone is gold and the screen was black..
por
Adicionar um comentário
1 resposta
Solução escolhida
After speaking to a screen supplier and repairer, apparently some iPhone 8 Plus’s get used to aftermarket screens and will only accept an aftermarket screen as compatible after only using aftermarket screens for a long time.. So I will try fitting a standard aftermarket screen and see if it works.. that’s a strange issue, so now I wonder if anyone knows how to gain compatibility back to the factory value, True Tone repair through JCID did not fix it.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Confirmed, tried several aftermarket screens all touch working, tried a couple more broken refurbs and originals, touch not working. For some reason this 8 plus only works with aftermarket screen replacements.
por
Adicionar a sua resposta
Becklyoh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 214
