Ir para o conteúdo principal
The Hover-1 Liberty is a self balancing e-scooter or hoverboard. It has a max speed of 7.4 mph, a max weight capacity of 160lbs, and it can travel 3 miles on a full charge. It also comes with LED wheels and Bluetooth capabilities. Model: HY-LBTY.
Hoverboard not turning on
Have green lights on charger till I plug into hoverboard and lights go out can anyone help me 🙏
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Could be the battery. If you don’t charge it very often then the battery can lose charge and if it drops below 30 volts the bms won’t accept a charge. Will probably need a new battery. Open it up and check the battery voltage with a multimeter.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Battery capacity is 25.2v, tested capacity is 24.7
por
You need a new battery as it's gone below voltage I'm afraid.
por
Thanks for that, will look for new battery 🤔👍
por
Do you know best place to get one from???
por
Battery is charged and ,each time I press the start button it kills the Battery of 8 volts in one jolt and won't turn on , with no signs of damage on the mother board or any components withing the unit .
Pontuação 0
Adicionar a sua resposta
Gary Alldis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 18
Últimos 30 dias: 29
Ao todo: 747
