Ir para o conteúdo principal
Netbook de 2008; Modelo ZG5 AOA150-1691; tela de 8,5"; processador Intel Atom N270 de 1,6 GHz
it's constantly power washing
whenever I turn the computer on it say this in the image
Imagem
it just does this on a constant loop. I'm assuming it's a critical error.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Chrome OS might be damaged in a way such that powerwashing doesn't fix the issue. I would recommend making a recovery drive for it using another computer. You'll need a flashdrive to save it to. You'll also need the exact model of your Chromebook.
You'll need to know the model of your Chromebook to select the correct version of the recovery media.
Google has a page for recovery that has all the directions and links to appropriate recovery media.
If that still doesn't resolve your issue, it's more likely this is hardware related.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nog será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 297
