Ir para o conteúdo principal
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
Screen says unable to update your fire stick TV
The TV has a blue screen with a small fire stick logo when it says unable to update your fire stick TV try disconnecting the power cable for a few seconds and then plugging it back in. It does nothing. I’ve forced it to reboot and comes back to the screen every time
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I believe this means your fire stick is not connected to your network and cannot install the updates needed to prepare for first run.
Esta resposta foi útil?
Pontuação 0
2 comentários:
So how do I enable it to connect to my Wi-Fi? Because I can’t get it to do anything besides try and update and then it says unable to update unplug it and try again which I’ve done multiple times and still nothing. So if you can’t get into the functions, how can you get it to connect to your Wi-Fi? I guess is the question?. Thank you.
por
It should have ask you which network you wanted to connect to.
por
Adicionar a sua resposta
JOHNNY USRY será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 238
