Ir para o conteúdo principal
8 inch tablet released in July of 2019. Came as a 32GB or 64GB model. The display is a TFT LCD with a resolution of 800 x 1280 pixels. Main Camera is a 8 MP camera and the selfie cam is a 2MP cam. The versions are: SM-T290 (Wi-Fi); SM-T295 (LTE)
Why my tablet is not charging until it's powered off?
My tablet doesn't charge until it's powered off. I've tried different chargers to check if may be the problem is with the charger but no. The problem is with my charging port that's why it doesn't charge until its powered off.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @bakhtawarzahid,
How long does the tablet stay on for when working on the battery only after it has been fully charged with the tablet off?
If only a short while then the battery may be failing and the charger can't do both i.e. charge the battery and operate the tablet at the same time.
Try replacing the battery and check if it now works OK.
Here's a video that shows what to do.
Search for SWD-WT-N8 to find battery suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Bakhtawar zahid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 391
