Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
Panic CPU x caller - rebooting every few seconds
I need some help. My iPhone restarts every few seconds when I unlock it. When it is locked it works all the time without rebooting.
I read the error code but I don't know what it means, can someone guide me where is the problem?
Panic code
{"bug_type":"210","timestamp":"2023-06-28 03:14:09.00 -0700","os_version":"iPhone OS 16.5 (20F66)","roots_installed":0,"incident_id":"D6DCF4B5-6A5E-446E-B318-FC8AB236FECB"}
  "build" : "iPhone OS 16.5 (20F66)",
  "product" : "iPhone10,3",
  "socId" : "8015",
  "socRevision" : "11",
  "incident" : "D6DCF4B5-6A5E-446E-B318-FC8AB236FECB",
  "crashReporterKey" : "c27374456cd62022bf606fff6bdb02803499bb8a",
  "kernel" : "Darwin Kernel Version 22.5.0: Mon Apr 24 21:10:12 PDT 2023; root:xnu-8796.122.4~1\/RELEASE_ARM64_T8015",
  "date" : "2023-06-28 03:14:09.29 -0700",
  "panicString" : "panic(cpu 2 caller 0xfffffff0105e0f54): AOP PANIC - No pulse on 0x109b248 - main(4) - \nuser handlers:\ntraceBuffer : \n280000008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140008f0140\nNo pulse on
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Pergunta mais útil
We might need more of the panic, but in my recollection an “AOP No Pulse” panic often refers to the Taptic Engine (Vibration motor). That could also point to issues with the charge port since the Taptic Engine connects directly to the dock flex cable rather than the logic board. If you can upload a bit more of the panic it might help, there are sometimes some extra clues further in the text.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I added a link to the whole panic
but the vibration works normally after toggling the mute button on the side.
por
Hi,
I am having the same issue on Iphone X with the same error code. Have you been able to fix it ?
por
Hi,
Pontuação 0
I do not remember exactly. but it was something with the ambient light sensor on the upper flex. Replacing the sensor flex with flood iluminator and proximity sensor fixed the error, but faceid needs to be programmed and repaired. In my case, the error occurred after flooding the phone.
Pontuação 0
Adicionar a sua resposta
kamillski será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 83
Ao todo: 3,633
