My remote switch isn’t working as it was dropped in water
Esta é uma boa pergunta?
Water damage can be irreversible. However, if you’re able to open the key and use 90+% isopropyl alcohol and a tooth brush to give the board a good clean. A can of compressed air can help dry the components when you’re done.
Check the battery with a voltmeter to see if you need to replace it as well.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 143
@mohammedatwi always change a battery after liquid immersion!
por oldturkey03
