Why,no sound on calls but speaker works?
Changed Battery, all works exept the no sound on calls but if i press Speaker it is Ok,Sound on other apps Ok.
Esta é uma boa pergunta?
you need to check connector no.3 is in properly, it can be a little tricky. push the flex in until you meet resistance, not up to the white line it will be about 1mm from the connection, then push the lock down.
Esta resposta foi útil?
Hi Pollytinto,i didn`t realise that it slid into the connector(3) thank you so much. It is very difficult to connect and should be the first when replacing Screen assy. Thankyou Ted.S
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,829
