Ir para o conteúdo principal
The attached manual is directly from Acer. It includes complete step-by-step teardown of the Aspire 5732z.
4 Perguntas Visualizar todos
I can't install windows 10 with usb
There is a big problem faces me
I need to install windows 10 with usb
I press f12 to do boot
Then selected usb and press
Labtob restarted then nothing
I need to solve the problem
Thanks alot for everything
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @damynltfy,
Is the USB bootable, as you didn't mention if it was or not?
If not, here's how to create a bootable USB so that the Windows ISO can be loaded onto it and then you should be able to boot from the USB
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
د. أمينة لطفي será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 138
