Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
20 Perguntas Visualizar todos
Physically the stick is not resetting to the middle of the axis,
My PS5 stick, as the title states simply lays wherever my thumb leaves it, wondering what broke, it's new, and I haven't opened it in hopes PlayStation might repair it, but I'm not sure what i can do.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Is the L3/R3 input functional? Sometimes, the control stick cap is pulled up against the cutout, which might restrict movement a tad. Pressing the L3/R3 button in the usual manner brings it back into place. If that isn't the case, then it may actually be a faulty control stick module or a defect in the cap, in which case taking advantage of your warranty is not a bad idea.
Esta resposta foi útil?
Pontuação 2
2 comentários:
input is functional
tried pressing down on the stick to no avail, it still just sits wherever my thumb leaves it on the axis for constant input
por
@fhbgm9t3eqself In this case, if your warranty is still valid or if it's still within the span of its return period, I'd suggest either exchanging the controller or have Sony repair it for you so you don't have to go through any unnecessary hassle or risk. If it comes down to it, it's likely the control stick module that will need to be replaced. Removal and replacement of this component are processes that require soldering.
por
Adicionar a sua resposta
xenonzer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 29
Duração total: 512
