Ir para o conteúdo principal
Keyboard doesn't work after replacement
Imagem
Imagem
I replaced my keyboard because some keys were broken off and missing but the laptop still worked. After replacing my keyboard it shows these images and the power button is the only key on the keyboard that works and the mouse pad doesn't work. Does anyone know what they images mean?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Often I find the trackpad cable to the logic board is not properly seated or is damaged. Review this guide Substituição da placa lógica do MacBook Air 13" meados de 2013 jump down to Step 23. Make sure the cable is square in the socket and the clamp is folded down as it’s pressure is what makes the connection. Post some pics of the connection if you are still having problems so we can see things.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 219
