Ir para o conteúdo principal
Samsung's flagship tablet, released in March 2017. Identified by model number SM-T820.
Does replacing the Charging Port Assembly require any SOLDERING
@dadibrokeit
Hi again Jerry :
Another question for you or anyone. Does replacing the above mentioned Charging Port Assembly ( Galaxy Tab S3 9.7 SM-T820) require any SOLDERING to replace?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Barbara,
Assuming you're talking about the complete charging port assembly - the same one that's advertised here on iFixit - then no, you do not need to do any soldering to replace it.
After going through the Daughterboard Replacement guide, here are the tools you need.
  • Heat source: heating pad / iOpener / heat gun / blow dryer
  • Opening pick(s) / plastic card
  • Suction cup
  • Phillips #000 screwdriver
  • Spudger
Samsung Galaxy Tab S3 Daughterboard Replacement - iFixit Repair Guide
It appears that iFixit is out of stock on those daughterboards, but you shouldn't have any trouble finding a replacement on places like Amazon, eBay or AliExpress. Here's an example.
Charging Port Board For Samsung Galaxy Tab S3 9.7 SM-T820 / T823 / T825 / T827
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Barbara J Maggiani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 204
