Ir para o conteúdo principal
A van de quinta geração estreou no North American International Auto Show de 2007 com estilo exterior de Ralph Gilles.
Abs light is on
I'm looking for help with abs repair, the light has been on for a long time, the van runs good but I'm hoping to fix instead of ignoring I had to get a new transmission and the local mechanic couldn't figure out what the abs issue was
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There are many reasons why your ABS light might be on. In order to read the codes, you need a scanner that can read those code, which will give you a place to start. The most common reasons for ABS problems is a defective sensor or ABS module.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rocks Solid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 246
