How to replace memory
i need to remove the hard drive
Esta é uma boa pergunta?
While the SSD drive is removable as you can see here in Step 11 in this teardown which is exactly the same as your system MacBook Pro 13" Function Keys Late 2016 Teardown it uses a custom interface, so unless you have a second function key system to plug it into you can’t access the data within it.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 84
