Ir para o conteúdo principal
The Nikon D80 is a digital, 10.2 megapixel, single-lens camera that was released to the public in 2005. It is meant for digital photo-taking and filming.
"err" message on the display, the answer is not clear
Hi There,
I have a problem,
When I switch on my Nikon D80
On the LCD "Err" is flashing.
THe Flash doesn't pop up
The AF Doesn't work
The DoF preview doesn't work.
But the shutter works, but no images are stored.
Sometimes the Mirror stays up, until I take the next picture.
I Have a Service manual, but this error isn't discribed.
I somehow managed to work for 10 Pictures but then the same happened again.
Any Idears, what could be the Problem.
I Hope you can help me.
Best regards
Esta é uma boa pergunta?
Pontuação 12
Adicionar um comentário
13 respostas
Solução escolhida
Usually, on a Nikon D80 with an "err" message that won't go away, the Aperture Control Unit must be repaired or replaced. There is a small switch contact held on by a small plastic rivet in the Aperture Control Unit that tells the electronics module in the camera what phase the camera is in during its cocking cycle. When that small plastic rivet breaks, the camera can't determine where it is in the cycle and just stops and displays the "err" message.
There are 2 ways of fixing the problem, replacing the part with the same plastic-riveted switch contact or taking the Aperture Control Unit apart and replacing the plastic rivet with a small steel screw which can't break again. I've been using the second method for 3 or 4 years now and haven't had a single body experience the same problem again.
Bob Kilbourn
http://www.camerarepairs.com
Esta resposta foi útil?
Pontuação 5
2 comentários:
@Bob Kilbourn
Could you please provide more information about the location of the switch with the plastic rivet on the Aperture Control Unit of D80. I have mine apart but cannot locate the switch. I am looking at the long motor and the gears it moves up to the lever that pushes the aperture lever in lenses and the lever that loads the shutter mechanism but no switch there. Only a rotating-sliding three contacts switch in the gears and an optical movement detection system with a wheel like those used in the old ball-mouses. Thanks for your help so far. Pirro.
por
@Bob, where did you get the replacement part?
Thanks
Jose
por
Addressing the "err message" in the Nikon D80 caused by the failure of the switch contact in the aperture control unit. The general disassembly of the D80 is not covered here. However, once access is gained to the mirror box, remove the entire aperture control unit assembly.
With the aperture control unit assembly removed, remove aperture control unit motor from the assembly.
Then remove the bottom of the housing for the contact gear.
Finally, access broken plastic post that retains contact on the gear and replace the broken post with appropriately sized screw (a very tiny and short screw will be needed).
Pontuação 4
5 comentários:
Where can I get the screws? what's the size? is there a step by step on how to access and remove the ACU?
por
Intéressant. Mais il faut que j’apprenne à démonter l'APN!
Merci
por
Where can we get the parts needed?
Thanks
Jose
por
Just did this repair. iPhone 5s have 2 screws that hold the glass back on, they work great, perfect diameter, had to cut it a bit shorter but worked perfectly
por
I'm not sure where I can get the screws. How big is it? Is there a step-by-step procedure for gaining access to and removing the ACU?
Please read our website and visit for more information:
https://www.appssmash.com/granny-mod-apk...
por
It seems to me the problem with the phase switch in the ap control is the design of the contacts not the plastic rivets per se and by the time you reach the point of rivet failure the contacts are quite worn, so I say replace the switch don't bother to repair it. Moreover, the design of the contacts has been improved perhaps for a later model that retro fits into the D80, that I don't know, just a guess. The last one I bought was $11. Plus my labor.
Pontuação 2
1 comentário:
Where did you purchase the part you replaced?
por
My D80 had a similar problem, displayed Err, wouldn't auto focus, hear the shutter no image saved. The images on the card could still be viewed. The manual states on page 132 that Err blinking is a camera malfunction and to send it in for service.
According to the authorized service center in my area the problem was;
Err Not Working.
Mirror / Box Operation Repaired
Aperture Mode / Operation Repaired
Checked and cleaned.
Replaced part, Aperture Control Unit $32 plus 2.48 tax.
$259.48 total cost with labor.
I can't say if this is a solution for you, but I was happy to pay for the service, these guys were very old school and I was glad I could support a small shop.
Pontuação 1
I have a D80 bought october 2008. The Err problem occurred after a year of two of (light) use. I got it repaired at the regional Nikon service center for like 200 euros. This year again the same Err problem, repairs would costs again 220 euros. It's hard to tolerate this from a semi-pro SLR.
Pontuação 1
The shop who sold us the D80, a serious shop, told me that repair is rarely possible, but evaluating the repair/damage costs around 130 USD in CH-Currency.
He: "Either get a second hand one, or a new one"
Rather surprising, how failure prone this brand is, isn't it?
I don't think to buy a new one - from this brand.
Pontuação 1
Try taking off the lens. Clean the contact points on the lens and the body of the camera, The contact points look like a row of dots where the lens connect to the camera body. The contact points can get dirty or greasy after some time. Using a micro-fiber cloth and denatured alcohol to clean the contact points. Be careful not to touch the inside of the camera body or the glass on the inside part of the lens. Reattach the lens and see if that worked. If not, try a different lens. Still not working... sorry that's all I got.
Pontuação 1
1 comentário:
It happened to me when I upgraded my FIRMWARE. Seems to be a firmware issue but cannot find any way to revert back to the old firmware. It appears to be an expensive paperweight. Tried the battery, contact cleaning, and new card. Help...cannot afford another Nikon.
por
"ERR" indicates one of several problems which the Instructions Manual does not fully explain or list the possible causes. One possible problem is that the camera has a mechanical or technical problem, which MAY necessitate having it checked by a qualified Nikon technician. On the other hand, it might be something as simple of a full memory card, or a defective memory card; remove the memory card and insert a new memory card.
Pontuação 0
possibly a damaged cam gear on the aperture assembly
Pontuação 0
Hi,
I got the "Err" display on the lED in my Nikon D80 suddenly when I turn on it to take few images. wouldn't auto focus, hear the shutter but no image saved. I go through all the above procedure, i.e., cleaning of the Aperture Control Unit, replace the memory card and the "err" is still coming on the LED. Could anyone please help me to come out from this. if the problem will not gonna solve then will send it to service centre.
Pontuação 0
I'm not quite understanding what needs to be replaced. What does the plastic post that retains the contact on gear look like?
Pontuação 0
2 comentários:
rickfeldman, the post by Phototronic on Jan 20 shows a photo of the gray gear with the metal switch contact on it. The constant pressure of the 4 brush contacts on the right side of the switch causes the gray plastic nub where the red arrow is pointing to break off. The plastic rivet is actually just a small post on the gear that is melted down when the gear is manufactured and is not a secure way to hold the contact. That's why replacing the plastic nub/rivet with a steel screw is a better option than just replacing the gear with another one from Nikon. The Nikon D90 has a similar gear system but it was re-designed to take some of the load off the plastic nub/rivet which resulted in a much more reliable part. Alas, the D90 part is not backwards compatible with the D80 part.
Bob Kilbourn
por
Hi Bob,
Thanks for sharing the information. Just to mention that the website you have mentioned has a typo. It should be www.camerarepair.com as opposed to www.camerarepairs.com.
Thanks
por
Hello guys,
my camera has the exact same issue and thus I opened it to fix it. Now I've fixed it and mount all parts together.
Just the ‘preview switch (unit)’, how it is called in the manual, seems to not fit together anymore. There is a switch which seems to me like being in another position and thus it doesn't fit anymore. Though I can't remember having changed any position of any switch and further took a lot of care not to do.
Anyways, does anybody know how to bring the switch in the right position or how to mount it again?
Greetings Sebastian
Pontuação 0
Got exactly the same prob. the thing is, i really wanna repair it! But sadly it looks to complicated to take whole camera apart to fix the tiny lil wheel with the af-contact…weird that all older D80 seems to break at the same point…lol…
Pontuação 0
Adicionar a sua resposta
mrsasha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 58
Últimos 30 dias: 306
Ao todo: 147,848
