Ir para o conteúdo principal
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
54 Perguntas Visualizar todos
Why is the car still leaking antifreeze, new gaskets, new reservoir, h
Why my car still leaking antifreeze, new gaskets, new reservoir, hoses good and tightened
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you checked the surfaces you applied the new gaskets to, as well as all hose nipples? Look for hair-line cracks and score marks from the removal tools. Hose nipples can be made from a softer metal like brass (which can also be plated to make it look like something harder). Softer metals are very easily scored by a knife or other hose removal tool and you will always get a leak when those marks score a line through the serrated nipples. You will need to file down through the mark, but in such a way that preserves the exact shape of the step. If you muck it up, buy another nipple (cheap). Never assume that because a professional has done the job and tested it, it can't be done in a rushed, cheap manner. I've seen literally hundreds of nipples scored like this and they all deny doing it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kenya Rankins será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 9
