Ir para o conteúdo principal
The Motorola Moto Z2 Force was released in July 2017—with the model number XT1789. The Moto Z2 Force is an android based mobile phone that updates the pre-existing Moto Z2 Play phone.
16 Perguntas Visualizar todos
Tape used to secure ribbon cables
There is a thin, black, flexible tape used to secure the sockets that the ribbon cables plug into. The tape keeps the cable from pulling out as well as holding down the release lever. The tape is very delicate and conforms to wrap the object it is attached to.
See here
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
@jayhovajay44937 post a picture of what that all looks like Adicionar imagens a uma pergunta já existente
por
@oldturkey03 Done
The tape tends to self-destruct. It is very thin, plyable and sticky. It wraps around components it is placed on sealing away moisture and providing strain relief.
por
Adicionar um comentário
1 resposta
If your on about replacing the tape after a repair you can use kapton tape.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I am aware. Clearly, Motorola did not think this was the optimum solution. The tape they used totally formed around the socket and because it was stretchy it pulls the cable into the ribbon cable connector. My suspicion is that this also provides significant intrusion protection from moisture, contaminants, etc. So far no one can even tell me what this tape is called.
por
Adicionar a sua resposta
Jay Hova (Jay Hova 4x4) será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 281
