Why do I hear noise when I accelerate?
When I first start the car and I in drive, when I accelerate the car make loud noise that eventual dies down once the heats up?
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 718
@moniquegoings what kind of noise? Sounds like ? Where in general do you think that noise comes from (side, rear, front, bottom)? Any check engine lights on? Anything unusual when you drive your Rogue (other than the noise)? What exact year is your Rogue?
por oldturkey03
Pressing gas pedal when start to drive. I already had my catalytic converter replace. Rumbling sound in the front.
por Monique Goings
It a Rogue 2015
por Monique Goings
@moniquegoings do you hear that noise only when your Rogue moves or is the noise there when you are stopped and the engine running?
por oldturkey03
I have the same problem when I accelerate the car make a noise like something is getting on the tire and the car vibrates a little, the car starts doing it after a code p0841 appears, my is a 2019 rogue
por Ian santos
