Ir para o conteúdo principal
Informações de reparo e desmontagem do mouse sem fio Logitech MX Master 3. Lançado em 2019 e identificado pelos números de modelo MR0077, 910-005692, 910-005620 ou 910-005647.
Left click not working randomly
Hi There,
I have a 3 year old MX Master 3, that from time to time does not register left clicks. The click feels normal, but it doesn't happen on the OS. I tried it with Windows, MacOS and iPadOS all with same behavior.
Is it possible to replace the switch?
Thanks in advance,
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
just replace your left button switch, it should solve your problem
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks for this feedback. Where can I get the parts to do this fix?
por
I am also interested in this. Where can I purchase the switch?
also is the switch hotswap? or solder?
por
I dont know in your country, but in my country you can find it in online marketplaces
Just try to find 2 pin silent microswitch for the keyword
FYI you'll need soldering iron and tin suction to do that....flux and solder wick for additional for your board safety and cleaning the pad
por
i think Replace the switch is the only way to fix, you can also replace silent switch
Pontuação 1
Adicionar a sua resposta
Tarzur será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 97
Ao todo: 4,032
