Ir para o conteúdo principal
The second generation Pathfinder was introduced in late 1995 with more rounded styling. It was completely redesigned from the first generation, switching from body on frame construction to unibody construction.
14 Perguntas Visualizar todos
Rear Wiper Arm Wont Park
my 2002 Nissan Pathfinder rear wiper wont park back into its place after running it, and when its turned off, it makes a humming sound every few seconds until i manually go to the back and put it back into its saddle/parked area. how do i fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
https://www.youtube.com/watch?v=C3MXmBwN... seems to be the right youtube with the answer.
Update (07/07/24)
So it turns out all I needed to do was twist the arm a little bit and now it parks just fine.
Esta resposta foi útil?
Pontuação 1
The motor is most likely burnt out. That'd explain the repeated humming sound. Try replacing it.
Pontuação 0
2 comentários:
thanks! i will consider trying that, any idea how to replace the motor?
is there a how-to on this?
por
por
Adicionar a sua resposta
Ezra será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 87
