Ir para o conteúdo principal
Should I replace the whole bottom board or just the charging port?
I recently damaged my controller's charging port and I see that the replacement will be very difficult as I've also lifted a trace that sticks solder into a bottom anchor point. I tested the same controller with a charge and play battery and it works perfectly, except for the destroyed port
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Can you add pics of the board?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
That depends on how confident your are in your soldering skills and your ability to do a stable rebuild of whatever was torn up. It's definitely less expensive, but is not a repair I would have a soldering novice try.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Raptuno será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 18
