Ir para o conteúdo principal
The GeForce RTX 3090 Ti is an enthusiast-class graphics card by NVIDIA, launched on January 27th, 2022. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-350-A1 variant, the card supports DirectX 12 Ultimate.
1 Perguntas Visualizar todos
Gigabyte 3090 ti just quit.
I was playing high-end graphics using this card, I started seeing frame rate drops and thought it was my cpu. When I replaced my CPU and reinstalled everything the graphics card no longer was recognized. Is there a way to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Does the GPU`s fan spin? If not it could be that it's not getting power, so try and reseat the graphics card and make sure that the power cables are plugged all the way in on both the GPU and power supply side. If the fan does spin double-check that the cable to your monitor is plugged into your GPU, not the motherboard. I can`t tell if you mean it doesn't display anything or if you can get your computer to turn on and use integrated graphics. if The computer doesn't display anything and because you replaced the CPU there could be a change that your motherboard needs a Bios update to recognize the new CPU depending on how new it is compared to your motherboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
keith smithers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 33
Últimos 7 dias: 135
Últimos 30 dias: 162
Duração total: 1,094
