Ir para o conteúdo principal
The Philips Sonicare FlexCare HX6930 electronic toothbrush is manufactured by Philips and was released in 2007. Five different modes, designed to clean teeth more efficiently.
6 Perguntas Visualizar todos
Beeping, one long, two short
My trusty Sonicare has started beeping in a repeating pattern while charging. It still works, but only occasionally. Is this fixable or do I need to buy a new one? It is by far the best toothbrush I have ever had, so I don't want to just discard it without attempting a fix or knowing I need a new one.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Mine only works for about 2 seconds and stops
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Try this fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove the brush head.
2) use a screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of the base handle. allow it to air dry
5) allow the switch to air dry
6) reassemble
Esta resposta foi útil?
Pontuação 3
8 comentários:
my sonicare doesn't have a silver button, only a green one. And no screwdriver has been able to turn the base 1/4 turn. Any other ideas?
por
Mine also does not have a silver button. I think it depends on the model. I just held down the power button while the brush was on the charging base, per Hayden's instructions above. It responded with a series of vibration signals, then the beeping series stopped "like magic." So far, so good.
por
None of the above works
por
None of the suggestions work. Tge beeping is driving me crazy.
por
None of the suggestions work. The beeping is driving me crazy.
por
Exibir mais 3 comentários
Had the same issue. From what I can tell, it was telling me the toothbrush was still on while it was charging. (The battery died mid-brush.) I turned it off while on the base (don’t know if that matters) and the beeping and flashing lights stopped. Hope this helps.
Pontuação 0
Adicionar a sua resposta
Don H Smith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 45
Últimos 7 dias: 378
Últimos 30 dias: 1,425
Duração total: 33,809
